Special Deal - $97.99 For PIPO X7 Win8 Intel Based TV BOX
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Results 1 to 8 of 8
Thread: CWM Recovery Question
  1. #1
    Junior Member
    Join Date
    Dec 2013
    Location
    United Kingdom
    Posts
    17
    Question CWM Recovery Question
    So, I have an EKB311 (same as K-R42) and stock seems to be working ok, but I want to flash a ROM. For protection, I'd like to backup using CWM recovery. I have used this extensively on a number of phones.
    I flashed the K-R42 CWM Recovery from this page: http://www.freaktab.com/showthread.p...ery-for-rk3188
    It said that it flashed ok.
    Problem is, how do you boot into recovery? I've tried using the recovery button on the bottom of the unit. It turns the blue light off, but I don't see anything on my TV, HDMI signal disconnects. This happened before I flashed CWM as well. Booting into stock still works fine.
    How can I get to the usual CWM recovery menu? Once I'm in, can I navigate using my Logitec Wifi Keyboard that works in Android?
    Thanks.
  2. #2
    Senior Member
    Join Date
    Jun 2013
    Location
    us
    Posts
    155
    Search
    Do a simple Google on recovery and your device. Or try one of the reboot apps on the play store. That is if stock ROM is rooted.
  3. #3
    Junior Member
    Join Date
    Dec 2013
    Location
    United Kingdom
    Posts
    17
    Thread Starter
    It's stock with no root, or I would have used Clockwork Rom Manager to boot as recovery or terminal. I posted here as I spent hours on google and couldn't find anything.
    Quote Originally Posted by peety View Post
  4. #4
    Developer&Moderator leolas's Avatar
    Join Date
    Dec 2012
    Location
    Spain
    Posts
    3,940
    Re: CWM Recovery Question
    Quote Originally Posted by arkaydeus View Post
    Dont know in this concrete model, but in all devices I tried, pushing reset button while power on the device without any computer conected to otg port, the device boots in recovery mode.
    leolas.
    My devices:
    Imito QX1 (Sponsored by Bob Finless)
    Minix Neo X7&
    Minix Neo X8-H(Sponsored by Minix)
    MK902 (Sponsored by RKM)
    Ifive X3(partially Sponsored by Banggod.com)
    Beelink M8B&Beelink R89 (Sponsored by Beelink)
    Thanks to all of them I can try to support your devices
    If you want to invite me a coffee or beer you can do it with this button:
  5. #5
    Senior Member
    Join Date
    Jun 2013
    Location
    us
    Posts
    155
    Yup
    Quote Originally Posted by leolas View Post
    leolas.
    Bingo!
  6. #6
    Junior Member
    Join Date
    Dec 2013
    Location
    United Kingdom
    Posts
    17
    Thread Starter
    leolas.
    OK, so I managed to root successfully. I've got Clockwork ROM manager installed. I've tried terminal:
    su
    reboot recovery
    I've also tried directly from rom manager.
    When I do either of those, the blue light on the front turns red, then I get nothing on the TV.
    If I hit the recovery button, the same happens, I get nothing on the TV. I've tried HDMI and analogue.
    At this point I'm questioning whether the recovery is working fine. The above happened with stock recovery and the one I flashed. Does anyone have an alternative link for CWM recovery that I could try and which definitely works?
    Thanks.
  7. #7
    Join Date
    Dec 2012
    Location
    Spain
    Posts
    3,940
    su
    reboot recovery
    Thanks.
    I made a lot of recoverys for Kr42, Some people reports that in some lewys roms and some stock roms seem that stock or cwm recovery dont work , maybe something wrong with misc.img, maybe the kernel inside the stock recovery is wrong (so the cwm made with the stock like the base fail too ), I dont know because I dont have this device and I cant study it.
    leolas
    My devices:
    Minix Neo X7&
  8. #8
    Junior Member
    Join Date
    Dec 2013
    Location
    United Kingdom
    Posts
    17
    Thread Starter
    If anyone finds this thread, the solution was to install Lewy's T-R42 rom. Turns out that although my unit does not have bluetooth, it does have the newer hardware setup found in the T-R42 and not the K-R42.
    Firmware is here:
    http://www.FreakTab.com/showthread.php?t=9074
    T-R42 2.0 Board Firmware by lewy20041
    Not sure if there is a CWM Recovery only download for the T-R42 yet. If you think you have the K-R42 but nothing else works, try the link above. My unit also has EKB311 written on the underside.
    Sent from my Nexus 5 using Tapatalk
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
