New! 64GB VOYO Win8 Mini PC, $113.99 w/ Coupon DYYLAVEJ
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Results 1 to 3 of 3
Thread: XBMC MX Player settings?
  1. #1
    Senior Member jellywobbles's Avatar
    Join Date
    Mar 2013
    Location
    United Kingdom
    Posts
    249
    Question XBMC MX Player settings?
    Hey Guys:
    Where are the settings in XBMC that control what video player is used?
    My son has set his XBMC to run with default player & now wants to use MX Player and I cannot see how to change the settings.
    Is it possible to easily switch between video players?
    Live as if you were to die tomorrow. Learn as if you were to live forever
  2. #2
    Senior Member
    Join Date
    Aug 2013
    Location
    here i'm
    Posts
    879
    http://wiki.xbmc.org/index.php?title...ers_on_Android
    First.. what version xbmc are you running?
    second.. did you make a 'playercorefactory.xml ?
    3... what version of mx did you install 'free' or 'pro' ?
    if you installed a xbmc version that has external support.. enabled
    -then its browsing to the movie link.. click on scroll button, play using : (this list the video player options)
    --older version like 12 have this symbol/button '>'
  3. #3
    Join Date
    Mar 2013
    Location
    United Kingdom
    Posts
    249
    Thread Starter
    Quote Originally Posted by mitchell4you View Post
    thanks for reply .. running xbmcapp-armeabi-050713.apk - no playercorefactory.xml to my knowledge.
    The MX installed is the FREE version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
