Special Deal - $97.99 For PIPO X7 Win8 Intel Based TV BOX
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Page 2 of 19 FirstFirst 123412 ... LastLast
Results 21 to 40 of 377
Thread: T-R42 custom firmware by wasser
  1. #21
    T-R42 Rockchip Passthrough Issue
    Current Settings:
    1) lewy20041 HWF 2.0.4
    2) Wasser New T-42 1080p Kernel with stock IR fixed
    3) Ethernet Connection
    4) MX Player (Latest version from Google Store)
    5) XBMC Gotham Alpha 8 libmedia Edition 2013-10-04
    Current Issues:
    1) After turned on Rockchip Passthrough, streaming a 1080p movie with DTS through MX Player video stuttering badly and unwatchable. My A/V Receiver keep switching back and forth between Analog and DTS. The same file played fine and smooth with Rockchip Passthrough turned off.
    2) XBMC Optical Passthrough not working and produced loud noise. (Looks like there is a patch to hack Passthrough for XBMC)
    Does anyone have same settings and same issues as mine? A combination of lewy20041 HWF 2.0.4 and Wasser New T-42 1080p Kernel with stock IR fixed would be perfect and winner for me if I can get these two issues resolved.
  2. #22
    Quote Originally Posted by wasser View Post
    i recommend to flash the cusomer t-r42 firmware.
    Hi Wasser,
    Thanks for the info. I will flash the Cusomer T-R42 Firmware you provided and see if my issues with Rockchip passthrough are resolved. If not, I'm going to flash back the stock firmware for T-R42 just released and wait for it's custom ROMs.
    What kernel did you use for the the Cusomer T-R42 Firmware? Is it 1080p with 1800/600/720?
  3. #23
    Senior Member michael2t's Avatar
    Join Date
    Aug 2013
    Location
    usa
    Posts
    228
    Hello Wasser
    Hello Wasser,
    I re-flash the Player with Your custom Firmware ...
    I see Your Boot Animation with the 4 Color X and Your New Home screen
    It boots fine ... Connects to Ethernet Fine ..
    I go in to the Normal Android Settings Page and
    I have issues when I go to Change From Ethernet to Wifi it reboots ...
    Then Turns back on the Ethernet ...
    This works fine in the System we made with Lewy's 2.0.4 ..
    It just takes a very long time to boot with Lewy's version ...
    But I can Select Wifi and Blue-tooth and Ethernet with out any problems ...
    Michael T.
    K-R42 & T-R42 box, 1.2.5/1.2.5-4 firmware By Wasser/ My Standard Remote IR Geekbuying
    CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
    Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
    Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
  4. #24
    Member
    Join Date
    Sep 2013
    Location
    Nova Scotia
    Posts
    76
    Same results here...
    Fresh reinstall of the OEM T-R42 rom, then installed Wassers ROM. Looked fine until I turned on wifi, then it rebooted.
    Reinstalled the OEM ROM, rooted, and I've attached the dmesg and lsmod outputs if you still need them.
    Bill
    Attached Files Attached Files
  5. #25
    Junior Member
    Join Date
    Oct 2013
    Location
    Thailand
    Posts
    2
    Red face
    This customer firmware can be use Android TV Box CS918 with Blutooth yes or not
  6. #26
    Member
    Join Date
    May 2013
    Location
    Germany
    Posts
    32
    Test report
    it would be nice of someone could post some feedbacks to the rom
    thanks
    Hi wasser,
    here is my test report for your ROM:
    After a little trouble of driver and flashing issues I was able to install your ROM with your 720p Kernel.
    Upon installing and rebooting the box goes to recovery menu. There you need a usb wired mouse to navigate.
    The cache and data partitions are not wiped after the flash process. So I had to do a factory reset (including wiping of cache and data partitions).
    Reboot... and after little time there is the homescreen.
    I'v tryed to install some apps from my external sd-card, but unfortunalety there is no pre-installed filemanager. So you need a google account to download it via play store.
    Okay.Turn on W-Lan -> Reboot...
    It's not possible to get the box started again...
    -> factory reset via cwm...
    How to enter the recovery menu:
    -press and hold the "Reset" button
    -plug in the power cable
    -> the blue light goes on
    -> still hold down the "Reset" button until the recovery menu comes up
    -to navigate you need a usb-wired mouse
    -Ethernet via LAN works fine
    -Bluetooth and Ethernet via LAN works fine
    -analog ausdio works fine
    Problems in this ROM:
    -W-LAN does not work -> Reboot
    -no pre-installed filemanager
    Steffen
  7. #27
    Junior Member
    Join Date
    Oct 2013
    Location
    Germany
    Posts
    9
    Quote Originally Posted by sgei View Post
    Hi wasser,
    Steffen
    Exactly my issues. I'm hoping for an update soon.
  8. #28
    ROM Developers
    Join Date
    Jul 2013
    Location
    germany
    Posts
    1,152
    Thread Starter
    i'm working on the fix for wifi issue, please patient!
  9. #29
    ROM Developers
    Join Date
    Jul 2013
    Location
    germany
    Posts
    1,152
    Thread Starter
    Quote Originally Posted by ppccrazy View Post
    i'm not sure if this firmware works on cs918.
  10. #30
    Join Date
    Aug 2013
    Location
    usa
    Posts
    228
    Wasser
    Hello Wasser,
    Good TO See you online...
    I was looking over Your new Firmware and comparing it to Leyw's 2.0.4 ...
    Which Works with Wifi and Your Kernels (thank You) ...
    As I was Going through the Build.prop ... I noticed that You use Rock_usb
    and Lewy's uses a Modified version he calls HWF_usb ... does that have any thing to do with
    the Problem(s) ???
    Where you able to Fix any of the other issues Sleep/resume/usb ???
    Please let Me know If there is anything I can do or test for You ...
    Keep Up the Good Work ...
    Michael T.
  11. #31
    ROM Developers
    Join Date
    Jul 2013
    Location
    germany
    Posts
    1,152
    Thread Starter
    Quote Originally Posted by michael2t View Post
    Hello Wasser,
    the Problem(s) ???
    Michael T.
    i uploaded the update for t-r42. It's made for my t-r42 firmware! and it's only installable over CWM. Please don't update it if your box has other firmware!
    The update should fix the wifi issue. It would be great if someone could please test and report! (i don't have the hardware to test)
    Don't forget to wipe cache and david cache after the update!
    http://d-h.st/PuB
    thanks
  12. #32
    ROM Developers
    Join Date
    Jul 2013
    Location
    germany
    Posts
    1,152
    Thread Starter
    Hello Wasser,
    the Problem(s) ???
    Michael T.
    the build.prop does not have to do with ssues Sleep/resume/usb. It's a problem somewhere in kernel.
    It seems this issue is fixed in my latest kernel for k-r42 which i will upload soon.
  13. #33
    Junior Member
    Join Date
    Oct 2013
    Location
    Germany
    Posts
    9
    http://d-h.st/PuB
    thanks
    Ja, that didn't go so well...
    After applying the update in CWM and rebooting, nothing appears on the TV. I can't say if it booted or not. Furtunately I made a CWM backup before applying the update and was able to roll back.
  14. #34
    Join Date
    Aug 2013
    Location
    usa
    Posts
    228
    Wasser's System
    Hello All,
    I have been working with Wasser's Kernels and images ... they are great...
    There seems to Be a Small issue with his Installer .. update
    So I downloaded it and Updated the System.img (By hand with his code) for all to Use ...
    All Thanks go to Wasser for his hard work and great Kernels...
    So Here is The Step-By-Step :
    1) You MUST do these In Order and Do Them all or for some strange reason
    it does NOT work ...
    2) Install the Stock Firmware ... From First Post on this thread ....
    3) Reboot the System and Make sure it comes up ...
    4) Then Flash all of Wasser's Images ... From First Post on this thread ....
    except replace his system.img with this one ...
    Link at bottom of post.
    Then Restart Start the System and You should be ready to go ...
    Wifi and Bluetooth and Ethernet all work fine ...
    Thank you Wasser for all your Hard work ...
    Enjoy All
    Michael T.
    Link : http://d-h.st/C8i
  15. #35
    Member
    Join Date
    Sep 2013
    Location
    Nova Scotia
    Posts
    76
    Installed the new system.img file and all seems well during my minimal testing! Wifi and BT anyway... Thanks to you both!
    Bill
  16. #36
    Thank's for all your hard work Wasser building this ROM nice and clean no junk no fuss just clean and fixed what more could you ask for
    Big thank's to mitcheal2t for fixing the bugs and making this ROM bugless
    Thank you both for all your hard work much appreciated please keep up the good work with this ROM
    My T-R42 only arrived this morning and had to get rid of the stock and move right onto the custom
    My Device: T-R42
    ROM: Wasser ?????
    Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
  17. #37
    Blank Internal Flash Problem
    Thanks Wasser for the great ROM and Mitcheal2t for fixing the Wifi issue.
    I got Ethernet, Wifi, and Bluetooth working again but now I have one issue with Nand Flash not mounted correctly. My internal flash showing 2GB and Nand Flash I got Blank Internal Flash. SD Card mount option is greyed out.
    Does anyone having same issue as mine after gone through all steps with Wasser's customer firmware?
  18. #38
    Join Date
    Aug 2013
    Location
    usa
    Posts
    228
    Hello xatang2013
    Hello xatang2013,
    I had this Issue .... But it is Resolved if You follow the Step I showed in my post.
    I had the same Issue... You MUST re-flash the Stock Firmware (and Reboot System To Make sure it is
    all correct) and then do the Updates ... Flashing of Wasser's Images and My new System.img.
    That fixed that issue for me ...
    Please Note: 2GB-RAM 8 GB NAND(OS is stored here also So NOT 8 gb where is left over)
    Internal Flash is 8 GB
    Not Really 8gb it is what ever is left over not used by OS/Firware ...
    SD card on RKexplorer is External SD card ...
    Plug Card in and SDCARD Highlights (mounts Automatically) and works fine ..
    Good Luck
    Michael T.
  19. #39
    My internal flash/sdcard is not mounted this gives me problems with certain apps any idea how to fix this please ?
    I get error no external storage availible
    Sent from my Nexus 7 using Tapatalk 4
    My Device: T-R42
    ROM: Wasser ?????
  20. #40
    Join Date
    Aug 2013
    Location
    usa
    Posts
    228
    Wapvirus,
    The Error message You posted is caused by not having the
    External SD card Plugged In ...
    Try Plugging a Micro SD Card Into your Unit and see if The Error messages
    Go away ...
    Michael T.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
