New! 64GB VOYO Win8 Mini PC, $113.99 w/ Coupon DYYLAVEJ
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Page 9 of 15 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 289
Thread: Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
  1. #161
    Junior Member
    Join Date
    Oct 2013
    Location
    Spain
    Posts
    4
    Quote Originally Posted by rrileypm View Post
    That GPS Test app is part of the stock ROM. I left it in because I thought it might be necessary for the GPS to work.
    Randy, but the M6 has not GPS. This app is not for this model. Itīs a litte bit curious that this app were part of the stock ROM.
    Thank you for your work!
    Sorry, I have post twice but I don.t know how to delete.
  2. #162
    Junior Member
    Join Date
    Oct 2013
    Location
    Chicago
    Posts
    5
    Here is the link to the stock ROM I used to create v1.8:
    https://docs.google.com/file/d/0B8nK...it?usp=sharing
    Randy, I've asked for your permission to access this file in google drive (email starts with "a..").
  3. #163
    ROM Developers rrileypm's Avatar
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,250
    Thread Starter
    That was the link that was provided to me by another user.
    Let me see if I can find my copy.
    I'll try to post a link for you.
    Randy
    Randy
    Freaktab Developer, Moderator and "Flashaholic".
    Thanks, for your continued support. Funds are low right now for new projects, so your help is greatly appreciated.
  4. #164
    Junior Member
    Join Date
    Oct 2013
    Location
    finland
    Posts
    2
    Is there something wrong with cwmrecovery.img ? Itīs size is quite small. I flashed RileyROM 1.8
    with cwmrecovery and after that system could not find sdcard. Same happened with rom 1.8a.
    There is an other cwmrecovery.img in post CWM for Pipo Max M6, whitch is mutch larger.
    I flashed my tablet with rom 1.8 with stockrecovery and after that I flashed again with only that
    big cwmrecovery and everything worked fine. I made with ROM manager 5.5.3.0 system backup
    to external sdcard and restored that back and everything seems to be OK. ROMmanager asked
    the cwm version and I guessed it to be the newer one.
    So once again: is the cwmrecovery.img in this post (size 1988 kt) corrupted???
  5. #165
    Junior Member
    Join Date
    Jul 2013
    Location
    germany
    Posts
    15
    AW: Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
    No, it's not corrupted. It is the generic version made by fun_. I use it since the first custom rom came up and it works like a charm. Cwm can't format the internal SD that's why you have to do it manually.
  6. #166
    Junior Member
    Join Date
    Oct 2013
    Location
    Hong Kong
    Posts
    23
    Post
    Quote Originally Posted by CiR3 View Post
    Thank you all, I try this option again. I download the cwm recovery with 22.xMB from the related thread, and flash Riley 1.8a as usual. Then, I flash the cwm recovery. At the beginning, seems everything go well even I installed over 50 apps. However, the problem occurs after I copied around 10 rmvb files inside the movies folder(10 files total 2.1GB). All apps keep force close after I copied the file through the USB cable. Then I restart the tablet, the tablet stuck on logo again.. I am quite tired to use this rom again as I flashed this rom over 6 times...I will try another roms, thanks anyway!
  7. #167
    Junior Member
    Join Date
    Sep 2013
    Location
    Portugal
    Posts
    2
    Help....does not boot after bad use of flash tool
    Hi, I was trying to flash my Pipo M6 with new 1.8 ( I had 1.5+1.6 kernel), but for mistake I click on Erase IDB after receiving an error that something went wrong with the Reboot3flash process.
    Now when boot the tablet, it freezes on rileyrom pipo max m6 artwork,
    As it freezes, i'm not getting PC to recognised the tablet, i cant even install manually the rockusbdriver !!
    How can I sort this out ?
    Thank you very much
    Filipe
  8. #168
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,250
    Thread Starter
    You can get into flash mode manually by following the steps in this thread:
    http://www.freaktab.com/showthread.p...ual-Flash-Mode
    Randy
  9. #169
    Junior Member
    Join Date
    Oct 2013
    Location
    finland
    Posts
    2
    What is the right way to format (erase???) sdcard when flashing rom with cwm.
    How and when should it be done?
  10. #170
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,250
    Thread Starter
    You need to do it each time you flash the whole ROM.
    Randy
    Randy
  11. #171
    Junior Member
    Join Date
    Jul 2013
    Location
    United Kingdom
    Posts
    4
    I keep getting a boot loop on 1.8a.
    It books fine once, but one I have installed some apps and stuff next reboot goes to the little rileyrom badge and just hangs there indefinitely. M6 Max 16gb wifi. I am using a 10gb partition.
  12. #172
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,250
    Thread Starter
    Have you tried flashing on of the other ROM's or stock firmware? See if that boot's and try to re-flash this one again to troubleshoot. Try a different parameter, too.
    I'm pretty sure other's are having success with flashing this ROM on their tablets. Also, make sure you are flashing the correct ROM. This is for the M6 Max...not the M6 Pro (pretty confusing, huh?).
    Randy
  13. #173
    Junior Member
    Join Date
    Jul 2013
    Location
    United Kingdom
    Posts
    4
    I have reverted to 1.7 and everything is hunky dory.
    I tried a couple of different partitions and same thing, must just be my tablet not liking 1.8a!
    Oh well 1.7 is no bad.
    Sent from my Galaxy S3 using Tapatalk.
  14. #174
    Member
    Join Date
    Jul 2013
    Location
    Perth, Australia
    Posts
    30
    Well looks like mine had died! Copied some photos over to the internal SD and it crashed in the process (first freeze in about 4 weeks) it now will not boot at all just stays at the riley rom logo..
    Must be copying of files over a certain amount that causes it.. out of interest is there space allocated to the filesystem and in this instance the filesystem data runs out of room?
    Flashing again soon.. may revert back to 1.7..
    Steve
  15. #175
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,250
    Thread Starter
    It looks like Pipo has a bug that causes a crash when you copy files back and forth from internal to external SD. That was reported a while back. I don't think they have released a firmware update since. The only way to solve this is to erase idb and flash again. The problem is less likely to occur if you have your external SD formatted NTFS.
    Randy
  16. #176
    Member
    Join Date
    Jul 2013
    Location
    Perth, Australia
    Posts
    30
    Thanks Randy... any of your sources indicating if there will be a new firmware at any point soon? been a while since the last one was released?
    Steve
  17. #177
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,250
    Thread Starter
    I'm still keeping my eyes open. None of my sources show any updates. I never know ahead of time...they just appear.
    Randy
    Randy
  18. #178
    Member
    Join Date
    Nov 2013
    Location
    Earth
    Posts
    39
    Deep Sleep resolved
    I have solved the problem with the deep sleep!
    I make 2 changes:
    1. rename /system/lib/libril-rk29-dataonly.so to libril-rk29-dataonly.so.old (with es file explorer)
    2. unpack the whole rom including the ramdisk (from boot.img) and make a comment to the following line in the default.prop:
    #rild3.libpath=/system/lib/libril-rk29-dataonly.so
    Afterwards I packed the whole rom again and flashed it.
    Now my Pipo M6 max uses correctly the deep sleep.
    I know that this makes the 3G modem useless but I don't use it anyways and the deep sleep is much more important for me.
    You can try if the first modification (renaming the libril-rk29-dataonly.so) is enough to solve the deep sleep problem. If not I can upload my modified rom.
    I am pretty sure that this will solve the deep sleep problem at the M6 pro too.
  19. #179
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,250
    Thread Starter
    Re: Pipo M6 4.2.2 RileyROM 1.8 [MAX not PRO]
    Nice discovery!!!!!!!
    I'm not sure if I will make this change in the ROM because it defeats 3G. But its here for everyone to try if deep sleep is an issue. I just turn my tablet off when I'm not using it.
    If you have a Linux box...or VirtualBox, there are some really good tools on Freaktab for making your own ROMs.
    If anyone wants to learn how...just watch for new threads from 900Supersport. He taught me...and is sharing his techniques with others.
    Sent from my M6pro using Tapatalk
    Randy
  20. #180
    Member
    Join Date
    Nov 2013
    Location
    Earth
    Posts
    39
    You just have to name a ROM with this modifications "Wifi only" and everything is alright.
    Wifi works as estimated.
    btw: where I can find the threads you mentioned?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
