New! 64GB VOYO Win8 Mini PC, $113.99 w/ Coupon DYYLAVEJ
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Results 1 to 15 of 15
Thread: Oma's CM10 for PIPO M9
  1. #1
    Senior Member
    Join Date
    Jan 2013
    Location
    Macedonia
    Posts
    175
    i have just found about this custom rom and i wanted to spread the good news (users reported that it works on Pipo M9 but the only issue is you dont have soft volume keys)
    mainly the dev made it for the Chuwi V88 but if you replace the kernel from the M9 it should work
    there should be no risk as soon as you dont flash the bootloader
    if you want to try CM10.1 alpha
    v1.2.1 with Android 4.2.2 click here
    for JB 4.2.2 SDK2.0 with multi window and working skype check this thread here
    or in case you want to try Oma's other roms like Paranoid or AOKP check here
    changelog
    First Android CM10 Test Build for rk31board
    - CWM 6.0.3.1 recovery
    - system ext4
    - kernel #11
    - internal Storage 4,0 GB
    - device spoofed as Nexus 7
    - ethernet support
    - init.d support
    - gameloft compatible
    - USB-Hub enabled
    - gamepad compatible (PS2, XBox, ...)
    - kernel modules (cifs, tun, lan, serial)
    - latest hosts, su, su-binary, busybox
    - MX Video-Player, Apollo & Volume +
    - Reboot Menue, CPU Tweaker, Pimp my Rom
    - Dateimanager HD (Root)
    - Trebuchet & Nova Launcher
    Instructions
    download both files cRom v1.0 / format_NAND
    Instructions are included in the download pack
    You just have to swap the kernel.img from the M9
    M9 Wifi and M9Pro
    M9 3G and M9 Pro 3G
    you can also swap kernel from the last update.img from pipo or riley
    As an extra measure of safety also used the latest bootloader from the M9 as this is the only part that would put the device @ risk of a brick! use latest bootloader from M9.
    As of time of writing the bootloader supplied by Oma is v1.20 and it should work fine.
    Rotation fix
    Edit build.prop
    ro.sf.hwrotation=270
    more info and pictures here
  2. #2
    Ive got this working fine with the Rileyrom 1.9a kernel,i flashed everything except the loader,only issue is no volume softkeys.
  3. #3
    Senior Member
    Join Date
    Jan 2013
    Location
    Macedonia
    Posts
    175
    Thread Starter
    what is the Antutu score
  4. #4
    Junior Member
    Join Date
    Aug 2013
    Location
    China
    Posts
    25
    Can it work for the PIPO M7Pro 3G version?
  5. #5
    Member
    Join Date
    Jun 2013
    Location
    Indonesia
    Posts
    94
    Oma says that to enable video HW acceleration, Bubbleupnp is needed. Can you check with popular video player like BSplayer if HW accel works? Thanks
  6. #6
    Senior Member
    Join Date
    Jan 2013
    Location
    Macedonia
    Posts
    175
    Thread Starter
    some good news
    the dev has already booted into Cyanogenmod 10.1 with android 4.2.2
    antutu score looks nice
  7. #7
    Senior Member
    Join Date
    Jan 2013
    Location
    Macedonia
    Posts
    175
    Thread Starter
    Alpha 2 Build
    some soft reboots
    while booting-up
    Oma RK31 CM10.1 Alpha Build v1.2.2
    02.09.2013
    - system ext4
    - latest kernel #109
    - PhabletUI & Multi-User
    - ethernet support
    - init.d support
    - USB-Hub enabled
    - Kernel modules (cifs, tun, lan, serial)
    - MX Video-Player, Apollo & FX Sound
    Not working:
    - auto rotation (use app rotate)
    - some soft reboots while filling dalvik, stable when boot-up fnished
    downloads:
    alpha 2 rom
    format_NAND_fix
    Instructions are included in the download pack.
    kernel archive
    screenshots:
    Click image for larger version.
ID:	3206 Click image for larger version.
ID:	3204 Click image for larger version.
ID:	3205 Click image for larger version.
  8. #8
    Member
    Join Date
    Jun 2013
    Location
    Indonesia
    Posts
    94
    Well initial test is not very good, clearly an alpha build. I flash it with version 1.2 of the bootloader and the kernel.img from Riley 1.9a. There's a 1.24 bootloader included but I did not try it.
    Oma does say that there will be soft reboot while filling the dalvik cache. What I experience is a LOT of these reboots, especially when doing some thing for the first time, like accessing a particular part of an app, running new apps, etc. It will soft reboot, showing the boot animation.
    Feature wise, WiFi does not work on first boot, but work after the first restart. The WiFi icon is grey the whole time, something I've never experience on a 4.2.2 ROM before. Connection seems OK and stable, however it's a bit flaky, in a sense, if I turn it off, I cannot turn it back on again unless I reboot the tablet.
    Bluetooth is not working, cannot turn it on.
    Camera also does not work properly, it will take pictures as normal, but the resulting photos are blank image.
    Antutu score is 14K ish, rather surprising since in the OpenGL ES 2.0 test I can see the FPS is higher than what I get with multiwindow version. Oma seems able to get 18K+ score on the V88.
    Hope the next release will be better
  9. #9
    Senior Member
    Join Date
    Jan 2013
    Location
    Macedonia
    Posts
    175
    Thread Starter
    i think it would be nice if he can read this post on xda so post it there too
    maybe he will reply or something
    well what can i say it is still an alpha build
    and yes dont flash that bootloader 1.24 , use only pipos m9 bootloader
  10. #10
    Member
    Join Date
    Jun 2013
    Location
    Indonesia
    Posts
    94
    Quote Originally Posted by mite_jan View Post
    Already did it just now . Seems I'm the first giving feedback there
  11. #11
    Member
    Join Date
    Jun 2013
    Location
    Indonesia
    Posts
    94
    Oma has released the Alpha 2 build http://crewrktablets.arctablet.com/?p=1950
    Alpha 2 Build
    some soft reboots
    while booting-up
    - system ext4
    - ethernet support
    - init.d support
    - USB-Hub enabled
    Not working:
  12. #12
    Junior Member
    Join Date
    Aug 2013
    Location
    China
    Posts
    25
    Quote Originally Posted by spectra9 View Post
    My device is M7Pro 3g and I flash the CM10.1 alpha3.I follow the instructions but the system can't recongnize the internal sdcard.The notification bar shows the sd card safe to remove.
  13. #13
    Member
    Join Date
    Jun 2013
    Location
    Indonesia
    Posts
    94
    Quote Originally Posted by winson10939 View Post
    Did you flash Format_NAND.zip using CWM on first boot? You have to copy this to your external SD card.
  14. #14
    Junior Member
    Join Date
    Aug 2013
    Location
    China
    Posts
    25
    yes i do.if I don't flash that zip it shows the sdcard is broken.
  15. #15
    Member
    Join Date
    Jun 2013
    Location
    Indonesia
    Posts
    94
    Sorry, I can't help you further then. Maybe you can ask Oma himself on his thread over at XDA. Good luck
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
