WeTekPlay Giveaway Action Win free WeTek Play with DVB-S2 or DVB-C/T/T2 Tuner
New! 64GB VOYO Win8 Mini PC, $113.99 w/ Coupon DYYLAVEJ
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
Thread: Ugoos UT1?
  1. #41
    ROM Developers rrileypm's Avatar
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,272
    Thanks, I'll take a look at it.
    I'm almost done porting a ROM that works pretty well...stay tuned!!!!!!
    Randy
    Freaktab Developer, Moderator and "Flashaholic".
    Thanks, for your continued support. Funds are low right now for new projects, so your help is greatly appreciated.
  2. #42
    Junior Member
    Join Date
    Aug 2013
    Location
    vietnam
    Posts
    9
    Quote Originally Posted by rrileypm View Post
    Just in case you want to play along...I have been testing different ROM's with this device.
    I've found out that Finless's new X7 ROM, here, boots and runs fine with the kernels (either one) included in his kit.
    The only problem is that wifi doesn't work.
    I'm trying to get wifi going, and hopefully we will have a ROM for the UT1 with all of the bells and whistles of Finless Bob's ROMs.
    I have tried both 1.2.1 and 1.2.0 and only 1.2.0 works for voice chat. So I just wonder the Finless's new X7 already included the voice chat function?
    Thanks,
  3. #43
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,272
    We still don't have a 1080p kernel, but I couldn't wait any longer to post a beta version of the ROM I've been working on all day.
    This is a port of the Finless ROM for the Minix Neo X7 he just posted yesterday.
    Basically, I took his system and recovery images and combined them with the UT1 kernel and boot images and copied the device drivers over from the stock system to Bob's X7 system...that took a while to troubleshoot. Wifi wouldn't work with the X7 kernel...so I had to make that work first and foremost. I found an error/bug in the stock recovery I dumped from my device which kept it from formatting the internal SD. Thankfully, the X7 recovery took care of that and all is now working.
    This ROM is:
    Rooted
    Google Play Store fixes
    Init.d support added
    Location Services enabled
    Gameloft fix added
    Debloated
    I can't tell at this time whether the vsync issue was fixed...since I'm using the Ugoos kernel. We will have to test and see.
    Here is the download link to the beta:
    Download
    I will be sure and post a new thread when all of the pieces are together.
    Please test away and enjoy!!!!!!!!
    Open the readme file and look it over before flashing....also I included a First Time User's Guide (Geared mainly to tablet flashing, but please read the part on installing the Windows drivers).
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
    Randy
  4. #44
    Junior Member
    Join Date
    Aug 2013
    Location
    vietnam
    Posts
    9
    Thanks rrileypm for your works. I tried this rom but still unable to support the audio. Could you please help to migrate the webcam support with audio from k-r42 1.2.0 hfw ver. to this rom?
  5. #45
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,272
    Ugoos UT1?
    Do you have any idea which files they are? I only want to move the minimum over to keep from breaking the wifi.
    Randy
    Randy
  6. #46
    Junior Member
    Join Date
    Aug 2013
    Location
    vietnam
    Posts
    9
    Randy
    Hi Randy,
    Sorry if I make you confuse. I tried to find the rom which have the audio support for webcam chat. And only rom k-r42 1.2.0 which is recommended by lewy20041 worked. Is it due to the original kernel?
    Thanks,
  7. #47
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,272
    Ugoos UT1?
    Ok.
    Does wifi work on that kernel? I couldn't get that ROM to boot on my device.
    See if you can boot this beta rom with that kernel and see what happens.
    Randy
    Randy
  8. #48
    ROM Developers lewy20041's Avatar
    Join Date
    Oct 2012
    Location
    Poland
    Posts
    1,504
    use kernel from 1.2.0 for usb audio.
    but you will have constant reboots.
    its kind of drm thing so you need to stick with k-r42 firmware.
    its not my idea;p
    Everything is possible if we work together!
    ApkFreak
  9. #49
    Junior Member
    Join Date
    Aug 2013
    Location
    vietnam
    Posts
    9
    Ok.
    Randy
    Yes, everything works quite well. Have to reboot sometimes due to the error "Unfortunately, Gallery has stopped" if I need to use the usb audio. And I can't use the remote as it's for UT1.
    Quote Originally Posted by lewy20041 View Post
    its not my idea;p
    yeah, I'm using this.
  10. #50
    Join Date
    Mar 2012
    Location
    Springdale, AR USA
    Posts
    10,272
    Ugoos UT1?
    Ok...it sounds like you have a unique application for this device.
    I will stick with the stock kernel in my rom, though...but refer others who need USB audio to try this. Yes it is a solution, but not necessarily ready for prime time...I see some support headaches going that route.
    I appreciate your testing of this and keep me posted on your experience. I have plenty to learn about TV boxes.
    Randy
    Randy
  11. #51
    Senior Member
    Join Date
    Aug 2013
    Location
    Brasil
    Posts
    100
    Can i flash it to mk809iii?
    Can you port it to mk809iii ou teach me how to change the drivers to work to my mk809iii?
    I want to play gameloft games with touch screen pinch zoom and these things working ok. can you help me?
    Mk809iii
  12. #52
    Junior Member
    Join Date
    Sep 2013
    Location
    canada
    Posts
    1
    Xbmc player
    Does UT1 come with Xbmc player pre-installed? If not, how to install it ? Please give details.
  13. #53
    Junior Member
    Join Date
    Oct 2013
    Location
    netherland
    Posts
    1
    Red face Ugoos UT1 Android 4.2 TV Box
    Ugoos UT1 Android 4.2 TV Box are amazing. Xbmc working als charm.
    here some link for EU http://www.myonlinewinkel.nl/ugoos-u...-hdmi-8gb.html
  14. #54
    Junior Member
    Join Date
    Oct 2013
    Location
    taiwan
    Posts
    3
    I disassemble my Ugoos UT1 lastnight (just bought it from China mainland whatever)
    The dealer told me that he can give me a good price if i take the Ugoos UT1, not the Kaiboer F4.
    He said that Ugoos UT1 is for export only, no retail in China.
    But I believe that Ugoos UT1 will be same structure as Kaiboer F4.
    Actually, The K-R42(CS-918) in China mainland has 2 kind of stock
    Genuine vs OEM, retail price was difference around RMB 80~100 (rmb470 vs rmb380)
    Ugoos UT1 spec detail:
    Rockchip RK3188 DU31EV 1321 (Quad-core ARM Cortex-A9 MPCore processor)
    SK hynix H5TQ4G63MFR-PBC *4 (DDR3-1600,256Mx16 4Gb DDR3)
    SK hynix H27UCG8T2BTR BC (8GB FLASH)
    Realtek RTL8188EUS 95J92H (IEEE 802.11b/g/n 1T1R WLAN, Max 54Mbps (G) and 150Mbps (N))
    ACTIVE 8846QM (Power Management)
    ITE IT66121FN (HDMI transmitter)
    Terminus FE1.1s USB 2.0 (USB 2.0 High speed 4-port hub controller)
    Rockchip RK1000-S H6R410 (Audio CODEC and TV Out chip)
    Trxcom TRC1102NL China M 1319 (RJ-45 LAN transformer)
  15. #55
    Junior Member
    Join Date
    Oct 2013
    Location
    USA
    Posts
    1
  16. #56
    Junior Member
    Join Date
    Oct 2013
    Location
    Germany
    Posts
    17
    Quote Originally Posted by kimfatt View Post
    Is the processor with or without heat sink?
    Best regards
    akapuma
  17. #57
    Junior Member
    Join Date
    Oct 2013
    Location
    taiwan
    Posts
    3
    Quote Originally Posted by akapuma View Post
    Best regards
    akapuma
    definitely no
    it's without heatsink
  18. #58
    Junior Member
    Join Date
    Jan 2014
    Location
    Tampere, Finland
    Posts
    11
    My review of Ugoos UT1
    Hi guys,
    Here is my review of Ugoos UT1:
    http://blog.arinium.fi/2014/01/revie...et-top-tv-box/
    -Ari
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
