New! 64GB VOYO Win8 Mini PC, $113.99 w/ Coupon DYYLAVEJ
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 146
Thread: Polaroid ROMS by Shawn
  1. #121
    Senior Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    231
    Quote Originally Posted by elektrik View Post
    Fair enough-has anyone actually found this to be the case? Main reason for asking is cause the netflix performance on my system suxors and I was hoping the ICS upgrade might help (not saying it will, just experimenting at this point).
    I'm also wondering about whether or not the S.T. "official" ICS upgrade actually kills the tv out function on the 701C or not. I don't think anyone has upgraded and then taken the time to verify. I upgraded via S.T.'s ICS update, but I don't have a cable so I can't verify.
    As for the ICS upgrade helping your performance on Netflix, I wouldn't get my hopes up. I've tried everything and then some to make it work well on my 701C running ICS. As flaky as the S.T. production of these tablets seems to be, who knows. Go ahead and give it a try but I can certainly tell you it did NOT solve my Netflix problems on my 701C. Like you, I was hoping it would. No dice.
    So far the most consistently successful setup has been running the old 1.5.2 version of Netflix on the stock 701C gingerbread rom. There is a very minor audio sync issue at times, but the video always played well.
    Don't want to hijack this thread and make it another thread hijacked by Netflix discussion so I'll say this quickly and let it be. Here are MY experiences with Netflix on ICS on the 701C. Maybe it will save you or someone else some time.
    For ME every version of Netflix I tested on the OFFICIAL polaroid/S.T. ICS 4.0 upgrade rom for the 701c ran terribly. Video and audio were jumpy, it would freeze, crash etc. This is true even when I tested with LiquidLimez marketfix and the other superscript floating around here.
    The closest thing I've had to success with Netflix running ICS on the 701C has been while using Shawn's ICS rom for the 701C and the LiquidLimez marketfix here. I'm not sure what is different between shawn's 701C ICS rom and the "official" polaroid/S.T. ICS upgrade rom, but Shawn's definitely gets me closer Netflix success than the official upgrade rom.
    Using Shawn's setup and the marketfix script I did notice Netflix ran beautifully on SOME/many videos. The audio and video were in perfect sync when it did play. I just had issues with it freezing at certain points in certain videos. It would typically do that at or near the same point. Play the same video on a pc, Xbox 360 etc and it plays through that same trouble point just fine. Whether it's a buffer problem, a problem with the Netflix app or what I can't say.
    Now to make sure I leave the thread on topic:
    Thanks for all the hard work you've done to date on the Polaroid Roms Shawn!!
  2. #122
    Junior Member
    Join Date
    Apr 2012
    Location
    Bloomington, IN
    Posts
    29
    Quote Originally Posted by shawnbusker View Post
    ROMS
    Polaroid 701c STOCK ROM
    Polaroid 701c Bloatware Free ROM
    Polaroid 701c Android 4.0 ROM
    Polaroid 701i STOCK ROM
    Polaroid 701i Gingerbread ROM (Coming Soon)
    Flashing Tutorial:
    1. Download Live Suite.
    2. Turn off your Polaroid Tablet
    3. Select the corresponding image file from inside Live Suite.
    4. Hold the second button from the bottom (menu) and plug your tablet in. (FEL Mode)
    5. Select Format Upgrade.
    Live Suite
    If you have any problems, questions, or concerns about this rom send me a PM. If you like my work, feel free to donate. (Help me buy a new PC so I can continue to make ROMS!)
    Has anyone successfully installed Shawns 701i Stock ROM on a 701i? I have Win7 64-bit and both LiveSuite 1.07 & 1.09. I get to the point where the file is selected and the cable is hooked up. The computer beeps when it detects the device and then Live Suite closes or hangs. I can flash the ST 701i 13 stock firmware fine (and have done so several times).
    Jim
  3. #123
    Junior Member
    Join Date
    May 2012
    Location
    United States
    Posts
    1
    FEL Fail
    I just bought the 701c. I cannot get into FEL mode in the way described. When I hold down the menu button... Windows 7 says it can't get a driver... though when I enter normal USB mode, it has no problem. Is there another way to get into FEL mode, or to image the Polaroid from its own memory? Thanks!
  4. #124
    Senior Member
    Join Date
    May 2012
    Location
    West Virginia
    Posts
    118
    Quote Originally Posted by mrhackman View Post
    If you download the official Southern Telecom ROM package, it has an additional driver install package in the LiveSuite directory called LiveSuitPack_version_1.07_20111026.exe. I had to install this and reboot before my drivers would work.
    Jim
    Ainol Novo 7 Elf II Dual Core
    Milestone (Droid) - Chevy SS GB ROM
    Milestone X - Rooted Stock GB ROM
  5. #125
    Junior Member
    Join Date
    Apr 2012
    Location
    Oklahoma
    Posts
    1
    Accidental flash of Polaroid 701i with 701c ROM
    I accidentally flashed the Polaroid PMID701i X10 with the Bloatware Free ROM (gingerbread 2.3.4, I believe) Shawn made for the Polaroid PMID701c . I have both the 701c and the 701i and I didn't pay attention to which tablet I grabbed. Well.... Everything seems to be working great (so far, anyway), although I did lose a lot of apps and the general setup I had spent so much time tweaking to my liking, it runs much faster than the ICS 4.0.3 that came on the tablet.
    Anyway, I also found that you do not want to "install" the drivers in Windows (Vista 32bit, in this case), by having Windows search for drivers and pointing to the Live Suite/USBDriver folder (yes, I plugged in the tablet before starting Live Suite, and Windows wanted to find some drivers for it, so I pointed it at the Live Suite/ USBDriver folder). Let's just say the tablet could not be recognized and Live Suite could not connect to it. Took me a while to figure this out, but after I uninstalled the driver (from Windows that is) and just let Live Suite find the tablet, everything worked fine. BTW, the reason I was needing to flash the 701c was that it flaked out on me yesterday and wouldn't boot up past the Polaroid screen. This is the second time this has happened to me in the last month, the first time I returned the tablet to Big Lots, but this time I was determined to find a solution to the problem, SO I have to say a big thank you to Team Dark Star for all of the work they put into developing the ROMs, without them I would be lost, without the tablet, and out the $98.00 I spent on the tablet. You guys rock. This site rocks. Thank you all.
    kbob
  6. #126
    Junior Member
    Join Date
    May 2012
    Location
    whydoyouwanttoknow
    Posts
    1
    hello, i would like to know if its possible to install on my polaroid 7'' tablet android 2.2, because i would like to have an other android rom for my polaroid. Im looking forward to hearing from you.
    regards,
    vincent
  7. #127
    Senior Member
    Join Date
    Mar 2012
    Location
    Charlotte, NC USA
    Posts
    197
    Quote Originally Posted by glimmerph72 View Post
    regards,
    vincent
    Hello!
    Sure - IF there was one out there for you to install. If somebody knows about one, speak up!
    However, with 2.3 and 4.0 ROMs out there for the 701x already, I could be wrong about this, but I don't think anyone's going to want to write a backport to 2.2 for you, if it's not already floating around out there somewhere...
    73 DE N4RPS
    Rob
  8. #128
    Junior Member
    Join Date
    May 2012
    Location
    USA
    Posts
    7
    Official S.T. Update
    Here's the office S.T. ICS update:
    http://southerntelecom.com/polaroids...mid701c40.html
    Didn't see it posted anywhere so thought I'd put it here.
  9. #129
    Junior Member
    Join Date
    May 2012
    Location
    United States
    Posts
    7
    is custom better than stock ics?
    a couple questions, I just got 2 for 89.99 woot! Thanks for all the hard work, my kids will love these on the up coming 10hr car trip
    So is Shawns ICS better than the ST ICS upgrade? (whats the difference)
    Is the google play store available with the ST ICS?
    How is volume controlled on the ICS updates without physical buttons?
    Quote Originally Posted by chudux View Post
  10. #130
    Senior Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    231
    Quote Originally Posted by housetube View Post
    Someone correct me if I'm wrong, but I don't think Shawn's ICS ROM is a custom ROM that involves any tweaks for performance. It's custom in that it was a result of his hard work to give people an ICS upgrade script for the 701C BEFORE S.T./Polaroid did. He also got us the stock rom's so we could restore firmware before S.T. released them.
    He has a debloated Gingerbread ROM but I don't think his actual 701C ICS rom is much more than a ICS rom reverse engineered from the 701i ICS rom so 701C owners could have ICS without waiting for Polaroid to get around to it. (Not that I'm making light of all the hard work he did. We're all truly grateful!)
    Do you have the 701C model? I really don't think one ROM is better than the other. Shawn just got it for us first so we didn't have to wait for S.T. because they kept postponing the release of firmware.
    If you have a Polaroid already running ICS there isn't any reason right now to change. If you have a Polaroid PMID 701C running Gingerbread then you could upgrade to either ROM. There honestly isn't much difference because they are both basically the 701i ICS ROM. I do know there was an issue with losing the function of some of the buttons when I rebooted with Shawn's ICS rom for the 701C. However it was easily fixed by swapping out a single file.
    As for the volume you change that with soft keys/buttons on the touchscreen just like Gingerbread because there are no hard buttons. However one of the things I like about ICS is you can generally get to the volume settings easier than with Gingerbread. With GB I noticed some apps and games made the task bar disappear and you had to back out to adjust volume which was annoying. With ICS you can generally tap the bottom of the screen when viewing video etc and it makes adjusting the volume less of a PITA in some cases.
  11. #131
    Senior Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    231
    One last thing...
    Just remembered the "official" 701C ICS Upgrade rom is pre-rooted.
    Not sure about Shawn's ICS rom for the 701C...
  12. #132
    Junior Member
    Join Date
    May 2012
    Location
    United States
    Posts
    7
    Thanks for the info, I have the 701c so I flashed shawns rom and everything seems to be working great. I love the access to controls in ICS.
    Quote Originally Posted by SingleDad View Post
  13. #133
    Senior Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    231
    I know...I like the controls, interface and settings in ICS much better too!
  14. #134
    Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    77
    Thread Starter
    Hey guys
    Hey everyone, I still haven't heard back from Southern Telecom since April, maybe if a few of you sent a couple emails to Nate, the customer support guy, about the success you guys are having from my roms, it might help persuade him into hiring me.
    His email is natef@southerntelecom.com
    If anyone does send him an email let us know if he replies.
    P.S, I have received my new computer (AMD A8-3850!) which means I can start working on roms again, but I don't have anything to work on currently, so if anyone has any ideas or projects they'd like to work on for the tablet, let me know, I'd love to keep working on roms for the tablet. I don't have a tablet anymore so anything I publish may be glitchy / not work, so feedback will be needed.
    Shawn
  15. #135
    Junior Member
    Join Date
    Mar 2012
    Location
    ca
    Posts
    7
    Shawn
    yes i have an idea an ics with limez scriot already cooked and in and debloated rom i mean really aol??
  16. #136
    Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    77
    Thread Starter
    Quote Originally Posted by dev131 View Post
    Well that can be done quite easily actually. If you have a tablet I can send you instructions on how to dump a rom and I can cook that into a rom for you. Just send me a pm with your email and your tablet model.
    Shawn
  17. #137
    Senior Member
    Join Date
    Mar 2012
    Location
    Charlotte, NC USA
    Posts
    197
    Just a LITTLE Longer...
    Hey, Shawn!
    I was going to PM you about this, but your mailbox is full. I guess business is booming, huh?
    Just sending you this to let you know I haven't forgotten my promise to you. I've just been waiting for Finless to root the NextBook 7s first. I'm just glad it all went off without a hitch.
    Now that he has cooked that ROM, you should have what I promised you by the end of the week. I'll spend a little extra, to get it there to you a little faster.
    73 DE N4RPS
    Rob
  18. #138
    Member
    Join Date
    Apr 2012
    Location
    United States
    Posts
    77
    Thread Starter
    Quote Originally Posted by N4RPS View Post
    Hey, Shawn!
    73 DE N4RPS
    Rob
    Yeah, sorry about that, if you need to send me a message send me an email at shawnbusker@gmail.com.
    So, how is the NextBook 7S? Any better than the Polaroid tablets speed wise or memory size?
    Shawn
  19. #139
    Junior Member
    Join Date
    Jun 2012
    Location
    OK, USA
    Posts
    6
    Screen Resolution?
    When I got my 701C, the resolution is low (larger font, large taskbar, larger on-screen virtual keyboard). Yesterday my 701C was trapped in boot loop (made a mistake on build.prop). Thanks to Shawn's nice work, I was able to flash the rom with de-bloated 3.4 ROM. The custom rom is really nice: Google Store, superuser, etc. To my surprise, the screen resolution seems to be incrased (smaller font and smaller on-screen keyboard). While it is nice to have more screen estate, I have hard to click on correct icon or keyboard keys.
    So I wonder if there is a setting that I did not know to change the screen resolution? Or there is something else going on?
    Also, I thought this rom is rooted. I just tried to run Titanium Backup, and it kept complaining not able to get superuser right. With stock rom, I have run it alright. Why did I have problem?
    Once again, thanks for saving my 701C!!!
    Edit: I found some free apps that set LCD resolution. Works like a charm. Apparently the build.prop has been modified in this ROM to have lower density (it should be finer but lower number in the file. Strange)
    And has anyone still active in this thread?
  20. #140
    Junior Member
    Join Date
    Jun 2012
    Location
    OK, USA
    Posts
    6
    Notification icons disappearing
    Another strange things about the custom 3.4 ROM is that the wifi icon sometimes disappear (even though I still got wifi). I also use the badass battery and its icon also disappear.
    And I still didn't get Titanium Backup to work. And one has suggestion?
    Thanks!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
