WeTekPlay Giveaway Action Win free WeTek Play with DVB-S2 or DVB-C/T/T2 Tuner
New! 64GB VOYO Win8 Mini PC, $113.99 w/ Coupon DYYLAVEJ
MINIX NEO Z64 Intel TV BOX Andorid /Wins 8.1 OS Available
Results 1 to 4 of 4
Thread: Can't unlock a Polaroid PTAB7200
  1. #1
    Junior Member
    Join Date
    Mar 2012
    Location
    Massachusetts
    Posts
    1
    My son created a password for his tablet and can not remember it. We are not given the option to have the password pattern sent to a Google email address. Pressing the Reset button does not help, and I do not know how to go into a Safe mode with the tablet. Does anyone know what we can do to get into this tablet again?
    Thanks in advance for any assistance!
  2. #2
    Super Moderator Damo's Avatar
    Join Date
    Jan 2012
    Location
    Hull, England, UK
    Posts
    3,404
    Quote Originally Posted by 1jackw View Post
    You can reflash the tablet with the firmware or a custom one(Bobs 1.4 Rom) but you will lose whatever programs are on there, unless you have a button for factory reset on the side or back of tablet, they are usually a small pin hole that you press
  3. #3
    Junior Member T7Sturgis's Avatar
    Join Date
    Feb 2012
    Location
    SD
    Posts
    10
    From Polaroid Website
    I have set a screen lock Password / PIN / Pattern and now forget my settings.You will have to perform a firmware update to the tablet. Be sure to back up any information and data to your computer’s hard drive as the tablet will be reset to a factory default setting and all of your data will be erased. To perform this firmware update from your computer log onto "www.southerntelecom.com/polaroidsupport/" and select “Updates”. From here you can get the firmware update as well as the Firmware Update Guide. Be sure to select the correct model number (located on the back of the tablet).
  4. #4
    Join Date
    Jan 2012
    Location
    Hull, England, UK
    Posts
    3,404
    Thanks T7sturgis
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
