WeTekPlay Giveaway Action Win free WeTek Play with DVB-S2 or DVB-C/T/T2 Tuner
Cube i6 Air 3G 64bit Dual Boot Phablet, $216.49 W/ Coupon KWJAMVKR
New! 64GB VOYO Win8 Mini PC, $113.99 w/ Coupon DYYLAVEJ
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: SDCard question
  1. #1
    Senior Member
    Join Date
    Feb 2012
    Location
    Uk
    Posts
    206
    SDCard question
    Might be a well known thing but it something i have just come across. I have inserted an 8gb micro sd and lost the links to the files and folders on the internal sd card.
    Anyone know how i can access the internal memory and the external sd card at the same time?
    Cheers
    Blinky
    Sent from my AN8G2 using Tapatalk
  2. #2
    Administrator Finless's Avatar
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    You should not loose them they should be combined. When no physical SD card is present there is still a part of internal memory mounted as sd card. When you stick in a sd card they should be there.
    Maybe look in /flash and see if they are there. But that should not happen.
    "Przebacz im, bo nie wiedzą, co czynią"
    "Прости их, ибо не ведают, что творят"
    "Perdónalos porque no saben lo que hacen"
    "Atyám, bocsásd meg nekik, mert nem tudják mit cselekszenek!"
    "Odpusť jim, neboť nevědí, co činí"
    "Πάτερ άφες αυτοίς, ού γάρ οίδασι τί ποιούσι"
    "Ojcze, przebacz im, bo nie wiedzą, co czynią"
  3. #3
    Senior Member
    Join Date
    Feb 2012
    Location
    Uk
    Posts
    206
    Thread Starter
    I thought that might be want was supposed to happen, but I can't find any of the folders on the internal memory till I take the card out. Will have another look in a little while, battery has died again.
    Cheers and will let you know the outcome.
    Blinky.
    Sent from my HTC Desire HD using Tapatalk
  4. #4
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    What tablet and ROM are you running?
  5. #5
    Senior Member
    Join Date
    Feb 2012
    Location
    Uk
    Posts
    206
    Thread Starter
    Sorry for the late reply.
    I have just flashed sowa's new rom with a clean sd inserted on an 8g2, still the same problem.
    After i install the sd i lose access to any files on the internal storage. They are only accessable once i remove the card.
    Settings>storage shows both cards there and show the used and free dara but i can only access one at a time.
    Any ideas?
    Blinky
    Sent from my Arnova using Tapatalk
  6. #6
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    I guess see if the stock ROM does that too. Might be a specific bug in the 8G2. The 10 G2 does not do that.
  7. #7
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    Wait... one other thing to check. Did you format the SD Card on a PC or something?
    Make sure the format matches. It should be formatted FAT32. If you formatted it NTFS or FAT16, etc this could be the problem.
  8. #8
    Senior Member
    Join Date
    Feb 2012
    Location
    Uk
    Posts
    206
    Thread Starter
    Right Bob I am totally confused.
    I have attached a picture of the file structure on the tablet. The two folders that I have underlined (badly) in red disappear when I mount the SDcard. If I connect to the PC then I can see the folders and there contents but not from the tablet.
    If I unmount the SD then the two folders come back. I have the SD formatted to Fat32, used the tablet to format it.
    Any ideas why I am loosing these folder when I mount?
    Cheers,
    Blinky
    .Click image for larger version.
  9. #9
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    OK ok.... so your looking int he wrong places.
    On the PC:
    When you turn on USB you should get 2 removable drives show up on the PC. One is the physical SDcard. The other is internal memory on the tablet.
    The SDCard removable drive is ONLY the physical SDcard. If you open that you will only see files on the Sdcard.
    If you open the other drive for internal memory you will see a directory called sdcard. That should be "some" of your files that went onto the sdcard in internel memory but possibly NOT ALL OF THEM. Why? Because the internal memory sdcard some folders in there get mounted as... believe it or not.... /system /data/ videos /pictures/ /android etc etc... So poke around in those and you should find all your files in internal memory that you "think" went to internal sdcard.
    In other words on the PC both sdcard mounts will show up different as they are mounted on the PC as different folders.
    Now on the Tablet and this gets tricky to explain:
    Lets use the STOCK file browser as it will be easier to see what is going on. Root file browser can confuse you as they show the true mount points.
    So shut off the USB to the PC.
    Now go in with the stock file browser and you should have this:
    SD Card
    Internal Memory
    USB
    Now when you open the SDcard it will ONLY be files on the physical sdcard!!!!
    Now open internal memory. You will see a SD card there but again THIS IS NOT the internal memory one! It is the physical SD card. However like above on the PC the internel SD Card is mounted as several folders.
    e.g. /music / video /DCIM etc. So again poke around in there. I bet you will find some of it in /data or /Android or possibly even in /system.
  10. #10
    Senior Member
    Join Date
    Feb 2012
    Location
    Uk
    Posts
    206
    Thread Starter
    Cheers for the reply. Still cant find the files.
    I have placed a text file in the folder i cant find called findme.txt. With the external card out i can do a search for the file and find it in the following path "/mnt/sdcard/external_sd/assorted apps/findme.txt".
    Once i mount the card that path no longer exists?
    Blinky.
  11. #11
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    It must be a common 8G2 bug then. This does not happen on my 10 G2.
  12. #12
    Senior Member
    Join Date
    Feb 2012
    Location
    Uk
    Posts
    206
    Thread Starter
    Cheers mate, will keep at it and see if i can find a solution.
    Cheers
    Blinky
  13. #13
    Senior Member hellfoot's Avatar
    Join Date
    Mar 2012
    Location
    philippines
    Posts
    129
    got the same problem...
    i'm trying to transfer wpa_supplicant file to my sd card with my a7bg2c using the usb cable
    and when i tried accessing it thru root explorer, cant find the sd card..only the itnernet memory appears on the root explorer..
    solutionlug out the usb cable and now the root explorer or just even the my files app can detect both the sd card and internal storage...
  14. #14
    Member
    Join Date
    Mar 2012
    Location
    Kent, England
    Posts
    40
    Bob, I'm having the same problem and I've got a 10G2 flashed with your 1.4 Rom.
    If without a memory card mounted, I put a file into sdcard directory, using ES File explorer, I can see it, with existing 'Files' ->Internal Memory->SD Card the file is there.
    Now if I then put in a memory card then the file is not there, using either of the above ways.
    If in ES, I change the home directory to '/' I can then go 'up' and see the flash directory you mentioned in earlier post, yet nowhere in that directory can I find the file either.
    If I then unmount and remove the card, then the file is findable again.
    Any ideas?
  15. #15
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    It's not just my 1.,4 ROM it is a STOCK ROM problem. Well not really a problem just how Arnova chose to implement!
    Read this post here about the 8G2 and what the issue is about.
    http://www.freaktab.com/showthread.p...ysical-sd-card!!!
    Again this has nothing to do with my 1.4 ROM or stock. it's all the same.
  16. #16
    Member
    Join Date
    Mar 2012
    Location
    Kent, England
    Posts
    40
    I wasn't implying that it was your ROM, just stating I was also having the problem and I've got a 10G2, whereas you said in post 11 that you didn't have the problem with your 10G2.
  17. #17
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    Well I always have a sdcard in so thats why I say I do not have a problem.
    The bottom line is Arnova chose to mount some part of internal memory as sdcard when yo do not have one. Anything you put in there is GONE when you put in a physical SDcard.
    Other tablets leave the internal one and mount the physical sdcard as /External_sdcard. So they remain apart.
    So if you understand how it works, you work around it.
    Another time, I will look at changing init.rc to make it work like other tablets.
    However THERE is a trade off and WHY some tablets do this. Some apps ALWAYS expect to put "data" in /sdcard. They may not know about /external_sdcard! So there are cases where you will never be happy with either implementation as an app you WANT to put data in external_sdcard will never happen and there is nothing you can do about it.
    So understand the issue. It is 2 sided.
  18. #18
    Member
    Join Date
    Mar 2012
    Location
    Kent, England
    Posts
    40
    I'm new to Tablets and Android but I understand.
    I don't know whether this is correct/dangerous/sensible, but...
    I think I have a workaround, if you connect a USB, and use a file manager, and connect to the Arnova Drive (not the sd-card one), you'll see several directories including DCIM, Pictures, Music, Video and sdcard (the disappearing folder).
    Now if you create a directory in this root folder (not the sdcard one), called something like MyFiles, then you can access any files you put in there from /mnt/storage/MyFiles and if they're pics/music etc. they also get picked up for the media library.
    Is there any reason I shouldn't do it like that?
  19. #19
    Join Date
    Jan 2012
    Location
    Stanton, California
    Posts
    16,195
    Quote Originally Posted by Gargoyle View Post
    You are totally FINE doing that. It will never go away. Only the sd card folder will. That is actually mounted as a partition but looks like a folder to the file manager. Makes sense?
    BTW I can show you a COOL TRICK!
    When you open internal memory and then SYSTEM then APK then COMMON. Any APK you put in here when you do a factory rerset, will be installed as part of the start up wizard! Very cool to quickly install APKs after a factory reset. However when you flash a ROM and eraseIDB, that area is gone. But it is a neat way to auto install apps on a factory reset.
  20. #20
    Member
    Join Date
    Mar 2012
    Location
    Kent, England
    Posts
    40
    Quote Originally Posted by Finless View Post
    As I said I'm new to tablets/android, so thought best to find out.
    Yep, that is cool.
    So after a new flash (1.5 should be soon ), if I copied any apk's of progs I wanted to there, then done a factory reset - that would install them all, as though they were installed with the new ROM?
    Sorry for being off-topic.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
