Special Deal - $97.99 For PIPO X7 Win8 Intel Based TV BOX DUAL-OS TABLET PCS Deals Collection
Page 8 of 38 FirstFirst ... 67891018 ... LastLast
Results 141 to 160 of 750
Thread: MK808 Android mini TV Player - Finless 1.5A Custom ROM
  1. #141
    Junior Member
    Join Date
    Oct 2012
    Location
    Espaņa
    Posts
    16
    Quote Originally Posted by natxito View Post
    I have had some problems building the driver... I use JRE 1.6 and probably I have forgotten some parameters in makefile file (type mismatch, paths, ...)
    Anyone could post an example of a working makefile for any driver, including complete makefile with paths and all that?.
    Thanks from a dummy (I am using Windows platform for building drivers)
    http://www.armtvtech.com/armtvtechfo...php?f=66&t=490
  2. #142
    Senior Member
    Join Date
    Oct 2012
    Location
    Canada
    Posts
    105
    You need to set the Govenor to : Performance for 1412 Mhz
  3. #143
    Quote Originally Posted by brucelee281 View Post
    I had the same problem one day, and found out that if you plug the ir part directly onto the usb connector that sometimes the 2.4 frequency interferes with the wifi signal because it's so close to the body. I then tried attaching it to the OTG port instead with the extra cable given. This gave it more room to breathe away from the mk808 body and it solved the trick.
    same here i tried to plug in otg port nothing changed. it still writtes multiple times.
  4. #144
    Junior Member
    Join Date
    Nov 2012
    Location
    France
    Posts
    5
    Quote Originally Posted by tashkas View Post
    In fact I still have multiple writes but far less than before. The trick is to bring the 2.4GHz dongle far from the device AND the charger! The 2Amps charger seems to irradiate in the 2.4GHz band and to jam signals.
    You can try another charger (2amps!!!!) and/or hide it in a metal box.
  5. #145
    Junior Member
    Join Date
    Oct 2012
    Location
    Poland
    Posts
    8
    To get good performance out of the MK808 use:
    1) HQ 2A/2.5A charger (CE and ROHS)!
    2) PS3 USB cable (or other HQ)!
    3) Put the 2.4GHz mouse/keyboard reciever on a long cable away from the device!
    4) Use Active and good quality USB hubs only (eg. Vivanco B-USB2 HUB 7A EDP 2.5A)!
    5) For cameras (skype) I recommend this one:
    http://www.logitech.com/en-gb/webcam...hd-webcam-c270
    6) To avoid problems, OC with a good setup (see 1 and 2)
  6. #146
    Junior Member
    Join Date
    Oct 2012
    Location
    spain
    Posts
    19
    drivers
    Hello, has not managed to install xp x86 drivers, and now it no recognize the device as new hardware.
    It may be to use windows xp?
    thanks
  7. #147
    Junior Member
    Join Date
    Nov 2012
    Location
    New Jersey
    Posts
    1
    Resolution problems
    HI
    I recently purchased the mk808, the only issue I am having is that I cannot seem to get the correct resolution to set. I have a Vizio 720 p tv and when I attempt to set it to the correct resolution under settings it continues to revert to 1080. The display looks very stretched. Can anyone help? Thank You
  8. #148
    Member
    Join Date
    Oct 2012
    Location
    Thailand
    Posts
    32
    NEW - MK808 Android mini TV Player - Finless 1.5A Custom ROM
    Just updated to 1.5a and play with it using stock power adapter. Wifi stayed connected during one hour with only one dropout. Great improvement.
    Thanks Bob.
  9. #149
    Junior Member
    Join Date
    Nov 2012
    Location
    Finland
    Posts
    4
    Thank's Bob, great ROM. Wifi works like a charm, and I am able to watch Netflix, use samba shares to watch movies (sd and hd), watch tv-streams, and so on. Also clocking with SetCpu works all right.
    However, in this topic some people have mentioned using XBMC.
    I've searched the internet and noticed that it would be possible to use XBMC with MXPlayer, however, haven't been able to do it myself as being an Android newbie I probably lack some skills here.
    The method (allthough for allwinners) is introduced here:
    http://www.j1nx.nl/allwinner-a10-xbm...rnal-mxplayer/
    More XBMC builds here: http://forum.xda-developers.com/show....php?t=1813089
    Has anyone been able to succesfully use XBMC with MXPlayer with MK808 ?
    If so, a step by step installation guide (for an android idiot) would be much appreciated...
    - Jarno, Finland
    MK808, Dovado 4GR router with NAS, LG50PK350 full hd plasma-tv, Deltaco TB-220 wireless multimedia keyboard with touchpad
  10. #150
    Member
    Join Date
    Oct 2012
    Location
    Thailand
    Posts
    32
    Hi Jarno,
    I follow this step and it works very well.
    http://forum.xda-developers.com/show...9&page=105
    Sorry, I was not as clear as I should have been. Don't worry about the sources, everything you need is in the dropbox link:https://www.dropbox.com/sh/zzeie8gnp6n4ze4/gS-4P_r1KK . When I made that post, MX 1.7 was still beta, so it and the codec had to be installed via APKs. Now they're in the Market, so install them from there.
    So to recap, install MX Player from the Play store and the appropriate codec for your system. Install xbmc from the dropbox link. I didn't mention this on reddit, but you'll probably want to run xbmc once so that it creates the files on the SD card. Quit xbmc, copy playercorefactory.xml to /sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/userdata. Start xbmc and you should be using MX!
  11. #151
    hi when i download it i get corupted zip file
  12. #152
    Member
    Join Date
    Nov 2012
    Location
    spela
    Posts
    33
    Cool Feature add
    Hi
    Could u apply librpc.so to kernel.
    So it will be possible to mount NFS shares via busybox?
    SMB is slow and not sutiable for moviestreaming.
    I would be really greatfull if you can do that.
    THNX
  13. #153
    Junior Member
    Join Date
    Nov 2012
    Location
    Finland
    Posts
    4
    Thank's bthoven, now it work's !
    -Jarno
    Quote Originally Posted by bthoven View Post
    Hi Jarno,
    I follow this step and it works very well....
  14. #154
    Junior Member
    Join Date
    Nov 2012
    Location
    Sweden
    Posts
    1
    SetCPU
    Hello!
    First time using setCPU, would like some help on how to use it.
    Also what is the default CPU settings for the MK808? I moved around the min and max settings when I installed setCPU and can't remember what the min and max should be.
    What is the optimal CPU settings for the MK808?
    A step by step description would be nice!-)
    And Bob; Great improvement on overall experience with the MK808 after installing your ROM
    Take care!
  15. #155
    Member
    Join Date
    Nov 2012
    Location
    Malaysia
    Posts
    31
    guide to flash finless 1.5A...
    try to search around for flashing guide for finless ....
    follow this guide below??
    http://blog.geekbuying.com/index.php...mware-release/
    anything i need to put special attention on??
    updated:
    Opsss...i noticed there is a full & detail guide inside the zip file....thanks
  16. #156
    Junior Member
    Join Date
    Nov 2012
    Location
    Sweden
    Posts
    8
    Hi Jarno,
    There is no folder named .xbmc and im not allowed to create it.
  17. #157
    Member
    Join Date
    Oct 2012
    Location
    Thailand
    Posts
    32
    Quote Originally Posted by paros View Post
    After installing xbmc, you need to run it once and close, then the folder will be created.
  18. #158
    Junior Member
    Join Date
    Oct 2012
    Location
    spain
    Posts
    19
    I managed to install the drivers, but not manually, but through windows 7.
    the remainder of the installation is very simple.
  19. #159
    Junior Member
    Join Date
    Nov 2012
    Location
    Sweden
    Posts
    8
    I had the latest version before i did install the one from the drop box.
    the folder is not created after running xbmc and closing it.
  20. #160
    Junior Member
    Join Date
    Oct 2012
    Location
    uk
    Posts
    1
    Use Ghost Commander instead, you will see the extra folder.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
